跳转到主内容
加入维修社区 - 创建账户
Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement
你所需要的
  1. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 步骤 2 中的图像 1,1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 步骤 3 中的图像 1,1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement, Haptic Motor: 步骤 4 中的图像 1,1
    • After removing the back cover, you will be able to gain access to the speaker component.
  5. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 步骤 5 中的图像 1,3 Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 步骤 5 中的图像 2,3 Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 步骤 5 中的图像 3,3
    • Pry the speaker up gently with the pointy end of the metal spudger.
  6. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 步骤 6 中的图像 1,1
    • Pull the red and blue wires from the green circuit panel.
  7. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 步骤 7 中的图像 1,1
    • When reassembling, you will need to use the soldering iron to solder the red and blue wires back to the circuit board.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 274
