跳转到主内容
Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement
你所需要的
  1. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement, Micro-USB Port: 步骤 1 中的图像 1,1
  2. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 2 中的图像 1,2 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 2 中的图像 2,2
    • Insert the tip of the nylon spudger under the black flap, and pull upwards toward yourself to disconnect it.
    • Be careful, as the flap can easily break off.
  3. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 3 中的图像 1,3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 3 中的图像 2,3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 3 中的图像 3,3
    • Using the T-5 bit, unscrew the three 5mm screws, two attached to the green board, one attached to the black board.
  4. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 4 中的图像 1,3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 4 中的图像 2,3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: 步骤 4 中的图像 3,3
    • Using the nylon spudger, remove the silver cylindrical component followed by the green then black components
    • Be careful not to break the wires that are holding the three components together.
结论
tate campbell
于09/17/18注册
439 声望
创作了3篇指南
团队
1指南评论
Is there a way to purchase a replacement battery?
Gasman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 502
