跳转到主内容
Vizio CT15 Speaker Replacement
你所需要的
  1. Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: 步骤 1 中的图像 1,2 Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: 步骤 1 中的图像 2,2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Speaker Replacement, Battery: 步骤 2 中的图像 1,1
  3. Vizio CT15 Speaker Replacement: 步骤 3 中的图像 1,2 Vizio CT15 Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Speaker Replacement, Speakers: 步骤 4 中的图像 1,2 Vizio CT15 Speaker Replacement, Speakers: 步骤 4 中的图像 2,2
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Speaker Replacement: 步骤 5 中的图像 1,2 Vizio CT15 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Speaker Replacement: 步骤 6 中的图像 1,3 Vizio CT15 Speaker Replacement: 步骤 6 中的图像 2,3 Vizio CT15 Speaker Replacement: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Speaker Replacement: 步骤 7 中的图像 1,2 Vizio CT15 Speaker Replacement: 步骤 7 中的图像 2,2
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 367
