跳转到主内容
Vivotek FD8169 Motherboard Replacement
你所需要的
  1. Vivotek FD8169 Motherboard Replacement, Dome Cover: 步骤 1 中的图像 1,1
    • Loosen the outside screw.
  2. Vivotek FD8169 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Press down on the side button, and lift up the top dome.
  3. Vivotek FD8169 Motherboard Replacement, Camera Module: 步骤 3 中的图像 1,1
    • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
  4. Vivotek FD8169 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift off the camera base from the motherboard.
  5. Vivotek FD8169 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unscrew the cord from the motherboard.
    • Unplug the remaining connection.
  6. Vivotek FD8169 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unscrew the camera from the camera base with a hex screwdriver on both sides.
  7. Vivotek FD8169 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull the camera out from the camera base.
  8. Vivotek FD8169 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
  9. Vivotek FD8169 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Once the screws are gone, lift the faulty motherboard and replace with a new one.
结论
Artem Dudko
于10/18/21注册
135 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-6, Simcock Fall 2021 UMass Dartmouth, Team 1-6, Simcock Fall 2021 的会员
UMASSD-SIMCOCK-F21S1G6
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 22
总计 248
