简介
Over time the frame counter in the camera will become loose. When this happens the user will not be able to tell what frame they are on when taking photographs. This leads to wasting film or ripping the film off the canister. This guide will show how to adhere a loose frame counter so the user can go back to shooting photographs.
你所需要的
Unscrew the front screws on the camera with a Philips screwdriver.
Unscrew the back screws on the camera with a Philips screwdriver.
Set the speed dial to Bulb mode and the ISO to the lowest setting before taking it off. This makes sure you are at the correct settings when it is placed back together.
Carefully put a flathead screwdriver into a notch in the middle of the dial on the center piece and turn it counter-clockwise.
Once loosened, remove the speed dial with your hands.
You're done! Go take some great photos!
2等其他人完成本指南。
