跳转到主内容
Vivitar Vivicam T027 Screen Replacement
你所需要的
  1. Vivitar Vivicam T027 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Vivitar Vivicam T027 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
  2. Vivitar Vivicam T027 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
  3. Vivitar Vivicam T027 Screen Replacement: 步骤 3 中的图像 1,2 Vivitar Vivicam T027 Screen Replacement: 步骤 3 中的图像 2,2
    • Separate the front piece of the camera from the back to reveal the motherboard.
  4. Vivitar Vivicam T027 Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic silver strip from the front case of the camera.
  5. Vivitar Vivicam T027 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
  6. Vivitar Vivicam T027 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Vivitar Vivicam T027 Screen Replacement: 步骤 7 中的图像 1,2 Vivitar Vivicam T027 Screen Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
结论
另外一个人完成了本指南。
Nicole Knoebel
于03/11/15注册
258 声望
创作了2篇指南
团队
Marist, Team 15-13, Laflen Spring 2015 Marist, Team 15-13, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S15G13
4 名成员
创作了3篇指南
2条评论
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - 回复
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 833
