跳转到主内容
Vivitar DVR 781HD Waterproof Case Lens Cover Replacement
你所需要的
  1. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement, Waterproof Case Lens Cover: 步骤 1 中的图像 1,1
    • Place waterproof case on flat surface, with the lens cover facing up.
  2. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 2 中的图像 1,2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
  3. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 3 中的图像 1,2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 3 中的图像 2,2
    • While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
  4. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 4 中的图像 1,2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 4 中的图像 2,2
    • Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
  5. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 5 中的图像 1,2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 步骤 5 中的图像 2,2
    • There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
结论
另外一个人完成了本指南。
Jordan Baum
于02/13/16注册
355 声望
创作了2篇指南
团队
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S54G6
3 名成员
创作了10篇指南
一条评论
Hello, do you know where I can acquire a replacement water proof case for my Vivitar DVR 787 HD action camcorder?
Andrew Hinsley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 1,249
