跳转到主内容
Vivitar DVR 781HD Motherboard Replacement
你所需要的
  1. Vivitar DVR 781HD Motherboard Replacement, Front Case: 步骤 1 中的图像 1,3 Vivitar DVR 781HD Motherboard Replacement, Front Case: 步骤 1 中的图像 2,3 Vivitar DVR 781HD Motherboard Replacement, Front Case: 步骤 1 中的图像 3,3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Motherboard Replacement: 步骤 2 中的图像 1,1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Motherboard Replacement: 步骤 3 中的图像 1,3 Vivitar DVR 781HD Motherboard Replacement: 步骤 3 中的图像 2,3 Vivitar DVR 781HD Motherboard Replacement: 步骤 3 中的图像 3,3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Vivitar DVR 781HD Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Motherboard Replacement: 步骤 5 中的图像 1,1
    • Gently lift the motherboard, handling it by the edges.
结论
2等其他人完成本指南。
Nathan McDaniel
于02/13/16注册
592 声望
创作了3篇指南
团队
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S54G6
3 名成员
创作了10篇指南
3条评论
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - 回复
How do you get a motherboard?
Rdam Russell - 回复
Where do we get one?
bikerbarbie29 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 1,441
