简介
This guide provides the instructions needed to remove the motherboard from the 781HD DVR camcorder.
你所需要的
Begin with the camcorder lens up on a clear working surface.
Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
2等其他人完成本指南。
3条评论
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - 回复
How do you get a motherboard?
Where do we get one?
