跳转到主内容
Vivedino Raptor 2 Hot End Removal
你所需要的
  1. Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 1 中的图像 1,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 1 中的图像 2,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 1 中的图像 3,3
    • Make sure all power cables to your 3D Printer are unplugged including wall plugs (A/C) and/or USB cables.
    • Remove the Print Head Assembly and move to a well lighted clean area.
    • Retain all parts and hardware for reassembly!
    • Use a #1 Phillips Screwdriver and remove the name plate.
    • DO NOT remove the hot end fan screws
    • Using a #1 Phillips and M2.5 hex, remove the screws securing the part cooler fan.
    • For the socket head screw, go to the next step.
  2. Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 2 中的图像 1,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 2 中的图像 2,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 2 中的图像 3,3
    • Hold the nut with needle nose pliers and remove the socket head screw and nut.
    • The final screw holding the part cooler duct on is accessed from underneath. Use a #1 phillips for this.
  3. Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 3 中的图像 1,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 3 中的图像 2,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 3 中的图像 3,3
    • Unplug the part cooler fan.
    • Unplug the hot end fan.
    • Remove the hot end fan and holder. Grab the fan with your thumb and index finger and pull it 180 degrees from the opening.
    • Using a small flat tip screw driver, loosen the phoenix connector to release the heater wires.
    • Unplug the thermistor connection.
    • Remove the bottom 2 motor screws.
    • Remove the 2 upper motor screws. They also hold the lever in place, which is under spring tension.
    • Squeeze the lever down while removing or installing the upper 2 to help align the holes.
  4. Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 4 中的图像 1,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 4 中的图像 2,3 Vivedino Raptor 2 Hot End Removal, Teardown: 步骤 4 中的图像 3,3
    • Loosen the 4 socket head cap screws with M2.5 hex until the horseshoe is loose.
    • Remove the horsehoe.
    • The hot end can now be removed by pulling it down and out of the printed body.
    • If it is stubborn, you can gently pry between the top fin and printed mount with a flat screwdriver.
  5. Vivedino Raptor 2 Hot End Removal, Measure and Rebuild: 步骤 5 中的图像 1,1
    • Now is the time to repair or replace your hot end.
    • Important Reminder: If you change any components, note the length of a few things...
    • The protrusion of ptfe tubing out the top.
    • The length of the hot end. Any change here will affect Probe Z Offset and may cause issues if too long or too short.
结论
另外一个人完成了本指南。
附加文件
Tiny Machines 3D
于11/16/19注册
2,970 声望
创作了14篇指南
团队
Tiny Machines 3D Tiny Machines 3D 的会员
Community
5 名成员
创作了40篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 919
