跳转到主内容
Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement
你所需要的
  1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: 步骤 1 中的图像 1,2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: 步骤 1 中的图像 2,2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 2 中的图像 1,2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 2 中的图像 2,2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 3 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 3 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 3 中的图像 3,3
    • Wedge a curved metal spudger under the speaker in order to remove it.
    • The speaker is held in place by an adhesive and can be difficult to remove.
  4. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 4 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 4 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 4 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
  5. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 5 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 5 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to lift the black tab.
  6. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 6 中的图像 1,2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 6 中的图像 2,2
    • Carefully lift and remove the ribbon cable from the black tab.
  7. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 7 中的图像 1,2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to remove the camera.
  8. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 8 中的图像 1,2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 8 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
  9. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 9 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 9 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 9 中的图像 3,3
    • Lift the tape holding down the battery.
  10. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 10 中的图像 1,2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
  11. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 11 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 11 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 11 中的图像 3,3
  12. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 12 中的图像 1,2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 12 中的图像 2,2
  13. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 13 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 13 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 13 中的图像 3,3
  14. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 14 中的图像 1,1
    • Safely remove the battery and motherboard from the tablet.
  15. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 15 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 15 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 15 中的图像 3,3
    • Lift the tape on the sides.
  16. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 16 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 16 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 16 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
  17. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 17 中的图像 1,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 17 中的图像 2,3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 17 中的图像 3,3
    • Wedge a metal spudger underneath the LCD screen to remove it.
  18. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 步骤 18 中的图像 1,1
    • Replace the front screen to replace the digitizer.
结论
Sabrina Scholten
于09/22/16注册
621 声望
创作了6篇指南
团队
UC Davis, Team 2-1, Oliver Fall 2016 UC Davis, Team 2-1, Oliver Fall 2016 的会员
UCD-OLIVER-F16S2G1
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 638
