跳转到主内容
加入维修社区 - 创建账户
Visual Land Prestige 7L Back Panel Replacement
你所需要的
  1. Visual Land Prestige 7L Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 Visual Land Prestige 7L Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Back Panel Replacement: 步骤 2 中的图像 1,3 Visual Land Prestige 7L Back Panel Replacement: 步骤 2 中的图像 2,3 Visual Land Prestige 7L Back Panel Replacement: 步骤 2 中的图像 3,3
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Back Panel Replacement: 步骤 3 中的图像 1,3 Visual Land Prestige 7L Back Panel Replacement: 步骤 3 中的图像 2,3 Visual Land Prestige 7L Back Panel Replacement: 步骤 3 中的图像 3,3
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
结论
另外一个人完成了本指南。
Robert
于01/28/15注册
141 声望
撰写一个指南
团队
Penn State, Team 2-25, Kaschak Winter 2015 Penn State, Team 2-25, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S2G25
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 618
