跳转到主内容
Visual Land Prestige 7G Speaker Replacement
你所需要的
  1. Visual Land Prestige 7G Speaker Replacement, Backplate: 步骤 1 中的图像 1,2 Visual Land Prestige 7G Speaker Replacement, Backplate: 步骤 1 中的图像 2,2
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Speaker Replacement: 步骤 2 中的图像 1,1
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Speaker Replacement: 步骤 3 中的图像 1,2 Visual Land Prestige 7G Speaker Replacement: 步骤 3 中的图像 2,2
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Visual Land Prestige 7G Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Take the soldering gun and place it on the black and red wires to melt the soldered conncetions.
    • Remove the speaker.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 28
