跳转到主内容
Visual Land Prestige 10 Motherboard Replacement
你所需要的
  1. Visual Land Prestige 10 Motherboard Replacement, Back Case: 步骤 1 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement, Back Case: 步骤 1 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement, Back Case: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Motherboard Replacement: 步骤 2 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 2 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Motherboard Replacement: 步骤 3 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 3 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 3 中的图像 3,3
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Motherboard Replacement: 步骤 4 中的图像 1,2 Visual Land Prestige 10 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Motherboard Replacement, Battery: 步骤 5 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement, Battery: 步骤 5 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement, Battery: 步骤 5 中的图像 3,3
    • Remove yellow tape from surrounding components.
  6. Visual Land Prestige 10 Motherboard Replacement: 步骤 6 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 6 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 6 中的图像 3,3
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Visual Land Prestige 10 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
  8. Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: 步骤 8 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: 步骤 8 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: 步骤 8 中的图像 3,3
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
  9. Visual Land Prestige 10 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Locate the LCD Connector.
    • Using tweezers, grip the small black tab connected to the white plastic.
    • Gently lift the tab towards you until it clicks.
    • Remove the connector by pulling straight out, gripping the black connector head.
  10. Visual Land Prestige 10 Motherboard Replacement: 步骤 10 中的图像 1,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 10 中的图像 2,3 Visual Land Prestige 10 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
    • Lift the tab towards you until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head.
  11. Visual Land Prestige 10 Motherboard Replacement: 步骤 11 中的图像 1,2 Visual Land Prestige 10 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Gently lift up the WiFi antenna and set aside.
  12. Visual Land Prestige 10 Motherboard Replacement: 步骤 12 中的图像 1,2 Visual Land Prestige 10 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
    • Gently lift up on the controller and leave it hanging loose.
  13. Visual Land Prestige 10 Motherboard Replacement: 步骤 13 中的图像 1,2 Visual Land Prestige 10 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove screws located on motherboard.
    • Place on magnetic mat and label them
    • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
结论
6等其他人完成本指南。
一条评论
I just received my tablet. and it will not allow me to set up a password. It keeps asking for previous password. I have done a hard reset but have not been able to set up my tablet.
John Jefferson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 1,596
