跳转到主内容
Visual Land Prestige 10 Back Case Replacement
你所需要的
  1. Visual Land Prestige 10 Back Case Replacement, Back Case: 步骤 1 中的图像 1,3 Visual Land Prestige 10 Back Case Replacement, Back Case: 步骤 1 中的图像 2,3 Visual Land Prestige 10 Back Case Replacement, Back Case: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Back Case Replacement: 步骤 2 中的图像 1,3 Visual Land Prestige 10 Back Case Replacement: 步骤 2 中的图像 2,3 Visual Land Prestige 10 Back Case Replacement: 步骤 2 中的图像 3,3
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Back Case Replacement: 步骤 3 中的图像 1,3 Visual Land Prestige 10 Back Case Replacement: 步骤 3 中的图像 2,3 Visual Land Prestige 10 Back Case Replacement: 步骤 3 中的图像 3,3
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Back Case Replacement: 步骤 4 中的图像 1,2 Visual Land Prestige 10 Back Case Replacement: 步骤 4 中的图像 2,2
    • Gently remove the speakers from the back case with tweezers and set the case aside.
结论
一条评论
Ok but where to I go to buy the replacement for the screen? This is directing us to take apart and reassemble the tablet, but not where to buy or get a new screen.
Jordyn Glenn - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,328
