跳转到主内容
Visioneer OneTouch 7400 USB Outer Case Replacement
你所需要的
  1. Visioneer OneTouch 7400 USB Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Visioneer OneTouch 7400 USB Outer Case Replacement: 步骤 2 中的图像 1,2 Visioneer OneTouch 7400 USB Outer Case Replacement: 步骤 2 中的图像 2,2
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Visioneer OneTouch 7400 USB Outer Case Replacement: 步骤 3 中的图像 1,3 Visioneer OneTouch 7400 USB Outer Case Replacement: 步骤 3 中的图像 2,3 Visioneer OneTouch 7400 USB Outer Case Replacement: 步骤 3 中的图像 3,3
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Visioneer OneTouch 7400 USB Outer Case Replacement: 步骤 4 中的图像 1,1
    • Separate the two casement pieces.
结论
另外一个人完成了本指南。
Jena
于10/18/13注册
608 声望
创作了6篇指南
团队
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013 的会员
UMAINE-DIAZ-F13S1G13
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 276
