跳转到主内容
Violin Strings Replacement
  1. Violin Strings Replacement, Strings: 步骤 1 中的图像 1,2 Violin Strings Replacement, Strings: 步骤 1 中的图像 2,2
    • Turn the peg belonging to the string you are wanting to change to loosen the string.
    • Violins have four string. The strings from left to right go: G, D, A, & E.
  2. Violin Strings Replacement: 步骤 2 中的图像 1,1
    • Pull the string out of the peg.
  3. Violin Strings Replacement: 步骤 3 中的图像 1,2 Violin Strings Replacement: 步骤 3 中的图像 2,2
    • Remove the opposite end of the string from the fine tuner holder.
  4. Violin Strings Replacement: 步骤 4 中的图像 1,2 Violin Strings Replacement: 步骤 4 中的图像 2,2
    • Place new string in peg hole.
  5. Violin Strings Replacement: 步骤 5 中的图像 1,1
    • Turn the peg to tighten the string.
  6. Violin Strings Replacement: 步骤 6 中的图像 1,2 Violin Strings Replacement: 步骤 6 中的图像 2,2
    • Place nub in fine tuner holder.
  7. Violin Strings Replacement: 步骤 7 中的图像 1,1
    • Make sure the string is sitting in the groove in the bridge.
  8. Violin Strings Replacement: 步骤 8 中的图像 1,1
    • Gently tug on string to make sure it is secure.
结论
5等其他人完成本指南。
团队
1指南评论
Thanks for this very clear set of instructions with clear images. I am an amateur violinist and broke a string while tuning. Even I could use these instructions and it was as easy as the post says. Thanks for posting and to ifixit in general.
Svasangana jeevi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 15,829
