你所需要的
在这个步骤中使用的工具:Tweezers$4.99
The tools you will need are:
Needle nose pliers
Slip joint pliers
A 9/32 &7/16 socket
Extension optional
A multi head screwdriver
Here you will need your 7/16 socket and your slip joint pliers. First you will need fit your 7/16 socket on the hex nut on the bottom of the machine and your slip joint pliers on the rod sticking through the top of the machine. You will then loosen the nut with your socket while holding the top with your slip joint pliers.
By doing this you will be removing the flywheel thus giving you more room to remove the electrical connections.
另外一个人完成了本指南。
