跳转到主内容
Vintage Mini Vornado Fan Blade Replacement
你所需要的
  1. Vintage Mini Vornado Fan Blade Replacement, Fan Blade: 步骤 1 中的图像 1,2 Vintage Mini Vornado Fan Blade Replacement, Fan Blade: 步骤 1 中的图像 2,2
    • Prop the cap out of each hole with a pry tool to remove the blade cap.
    • To remove the blade cap, you will need to pop out three different areas of the cap from the fan. There are three small holes around the perimeter of the fan that the cap is secured into.
  2. Vintage Mini Vornado Fan Blade Replacement: 步骤 2 中的图像 1,1
    • Face the front of the fan and pull the blade directly towards you to loosen it.
    • Pull the blade out of the rod.
    • Take note of the blade's orientation.
  3. Vintage Mini Vornado Fan Blade Replacement: 步骤 3 中的图像 1,1
    • If you have purchased a new blade, make sure the orientation matches the one you just removed.
  4. Vintage Mini Vornado Fan Blade Replacement: 步骤 4 中的图像 1,1
    • Use a cloth to dust the blade or other interior areas of the fan.
  5. Vintage Mini Vornado Fan Blade Replacement: 步骤 5 中的图像 1,1
    • Place the blade back inside of the fan.
    • The blade should fit snug when the rod is fully inserted.
  6. Vintage Mini Vornado Fan Blade Replacement: 步骤 6 中的图像 1,2 Vintage Mini Vornado Fan Blade Replacement: 步骤 6 中的图像 2,2
    • Place the blade cap on and secure it into the three holes.
    • Use a pry tool with a cloth to help apply pressure and push the cap into place.
终点
另外一个人完成了本指南。
Claire Minahan
于02/01/23注册
169 声望
撰写一个指南
团队
Cal Poly, Team 2-3, Johann Winter 2023 Cal Poly, Team 2-3, Johann Winter 2023 的会员
CPSU-JOHANN-W23S2G3
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 35
总计 334
