跳转到主内容
Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement
你所需要的
  1. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement, Needle/Stylus: 步骤 1 中的图像 1,3 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement, Needle/Stylus: 步骤 1 中的图像 2,3 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement, Needle/Stylus: 步骤 1 中的图像 3,3
    • Insert a prying tool into the stylus casing, right above the red casing.
    • Potential for device damage: Be delicate; if too much force is applied, the tone arm or stylus can break.
  2. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 2 中的图像 1,2 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 2 中的图像 2,2
    • Push the casing down with the prying tool, releasing it so it can be removed.
  3. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 3 中的图像 1,2 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 3 中的图像 2,2
    • Connect the new casing, applying it at an angle up and towards the back of the head of the tone arm.
  4. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 4 中的图像 1,2 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 4 中的图像 2,2
    • Move the new casing up and into place where it will lock.
    • You should hear a click sound when securing the casing.
  5. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
  6. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: 步骤 6 中的图像 1,1
    • Listen to how the turntable sounds when turned on. Listen for warbles, crackles, pops, and other non-desirable noise.
    • If these distortions are heard, the new stylus may not be installed correctly and should be reinstalled.
结论
If the vinyl sounds clear and plays smoothly, the needle has been successfully installed and ready for use.
Ben Schnuck
于02/25/21注册
133 声望
撰写一个指南
2条评论
My warranty is out (bought mine in 2017) and Victrola has been no help. They wont replace any parts, and so suggested I do an online search for 3rd party parts. But, I don’t even know what to look for. The arm on my unit is broken, what part do I need or what do I search for? I have the Model VTA-200B (music center with Bluetooth) Serial #: D170604182ITC. I tried to attach a pic, but can’t here.
Monica Addington - 回复
Hi Monica,
After doing some research, it seems like you can only really replace the needle. If the arm is broken, you may need to find that individual with the plastic motor for sale online. But I'm not having luck finding any Victrola arms for sale either.
Cordell Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 44
总计 3,437
