跳转到主内容
VersaMed iVent 201 Power Pack Replacement
你所需要的
  1. VersaMed iVent 201 Power Pack Replacement, Power Pack: 步骤 1 中的图像 1,1
    • Remove the four 3mm x 20mm Phillips screws located on the corners of the power pack.
  2. VersaMed iVent 201 Power Pack Replacement: 步骤 2 中的图像 1,1
    • Pull the power pack from the compartment using black handle.
  3. VersaMed iVent 201 Power Pack Replacement: 步骤 3 中的图像 1,1
    • Remove the five 3mm x 10mm Phillips screws and washers from the back of the power pack. Lift off the cover after.
  4. VersaMed iVent 201 Power Pack Replacement: 步骤 4 中的图像 1,1
    • Turn the battery pack upside down and take the battery out of the casing.
    • When reassembling, listen for the sound of the cooling fan for confirmation that the connection was successful.
  5. VersaMed iVent 201 Power Pack Replacement: 步骤 5 中的图像 1,1
    • Remove the two spade connectors using pliers.
    • When assembling the power pack, MAKE SURE to connect the red wire to the positive terminal and the black wire to the negative terminal of the battery.
结论
To reassemble your device, follow these instructions in reverse order. Caution: MAKE SURE THE RED WIRE IS CONNECTED TO THE POSITIVE TERMINAL AND THE BLACK WIRE IS CONNECTED TO THE NEGATIVE.
Jeffrey Yin
于04/09/20注册
265 声望
创作了2篇指南
团队
Cal Poly, Team S7-G17, Paton Spring 2020 Cal Poly, Team S7-G17, Paton Spring 2020 的会员
CPSU-PATON-S20S7G17
2 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 258
