跳转到主内容
Verizon Wireless CDM 7075 Keypad Replacement
你所需要的
  1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: 步骤 1 中的图像 1,2 Verizon Wireless CDM 7075 Keypad Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
  2. Verizon Wireless CDM 7075 Keypad Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the battery from the phone by prying the battery from the top.
  3. Verizon Wireless CDM 7075 Keypad Replacement, Keypad: 步骤 3 中的图像 1,1
    • Pry off the top cover on the back of the phone.
  4. Verizon Wireless CDM 7075 Keypad Replacement: 步骤 4 中的图像 1,1
    • You will then remove the screws from the back of the phone.
  5. Verizon Wireless CDM 7075 Keypad Replacement: 步骤 5 中的图像 1,1
    • Next you will pry apart the two halves of the phone.
    • Make sure you do not to damage the ribbon cable connecting both halves
  6. Verizon Wireless CDM 7075 Keypad Replacement: 步骤 6 中的图像 1,1
    • Then use the plastic opening tool to remove the motherboard from the front half of the phone.
  7. Verizon Wireless CDM 7075 Keypad Replacement: 步骤 7 中的图像 1,1
    • Next you will peel off the keypad after the motherboard is removed.
    • Be sure you do not to tear the brown connector tape.
    • Lastly insert the new keypad.
结论
To reassemble your device follow these instructions in reverse order.
另外一个人完成了本指南。
Corey Ryman
于10/14/11注册
255 声望
创作了4篇指南
团队
James Madison, Team 2-4, Allen Fall 2011 James Madison, Team 2-4, Allen Fall 2011 的会员
JMU-ALLEN-F11S2G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,133
