跳转到主内容
Verizon M1424WR Refresh Button Replacement
你所需要的
  1. Verizon M1424WR Refresh Button Replacement, Refresh Button: 步骤 1 中的图像 1,1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Refresh Button Replacement: 步骤 2 中的图像 1,3 Verizon M1424WR Refresh Button Replacement: 步骤 2 中的图像 2,3 Verizon M1424WR Refresh Button Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Refresh Button Replacement: 步骤 3 中的图像 1,2 Verizon M1424WR Refresh Button Replacement: 步骤 3 中的图像 2,2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Refresh Button Replacement: 步骤 4 中的图像 1,2 Verizon M1424WR Refresh Button Replacement: 步骤 4 中的图像 2,2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Refresh Button Replacement: 步骤 5 中的图像 1,1
    • Locate the refresh button.
  6. Verizon M1424WR Refresh Button Replacement: 步骤 6 中的图像 1,3 Verizon M1424WR Refresh Button Replacement: 步骤 6 中的图像 2,3 Verizon M1424WR Refresh Button Replacement: 步骤 6 中的图像 3,3
    • Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 360
