跳转到主内容
Verizon M1424WR Motherboard Replacement
你所需要的
  1. Verizon M1424WR Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Motherboard Replacement: 步骤 2 中的图像 1,3 Verizon M1424WR Motherboard Replacement: 步骤 2 中的图像 2,3 Verizon M1424WR Motherboard Replacement: 步骤 2 中的图像 3,3
    • Warning: The design and location of the plastic clips holding this shroud make it extremely difficult to release. Take your time and use a second pry tool if necessary.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Motherboard Replacement: 步骤 3 中的图像 1,2 Verizon M1424WR Motherboard Replacement: 步骤 3 中的图像 2,2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Motherboard Replacement: 步骤 4 中的图像 1,2 Verizon M1424WR Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Motherboard Replacement: 步骤 5 中的图像 1,3 Verizon M1424WR Motherboard Replacement: 步骤 5 中的图像 2,3 Verizon M1424WR Motherboard Replacement: 步骤 5 中的图像 3,3
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  6. Verizon M1424WR Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the front of the circuit board up from the bottom casing.
  7. Verizon M1424WR Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull the circuit board towards you until it is separate from the bottom casing.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 753
