简介
The capacitor is located on the circuit board. You will need to solder in order to replace the capacitor. For help with soldering techniques, click here.
你所需要的
Insert the new capacitor through the circuit board so that the prongs are exposed on the flip side.
Heat the prongs up with the soldering iron and touch a soldering wire to the hot prongs to attach the capacitor to the board.
即将完成!
To reassemble your device, follow Steps 1-7 in reverse order.
结论
