跳转到主内容
Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement
你所需要的
  1. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement, Battery: 步骤 1 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 2 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 2 中的图像 2,2
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 3 中的图像 1,1
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
  4. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement, SIM Card: 步骤 4 中的图像 1,1
    • Now that the battery is out, the SIM Card should be visible. Simply grasp it and pull it out of the device.
    • The device in picture no longer has a SIM card but a normal device will likely have a SIM card once opened.
  5. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement, Screen: 步骤 5 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement, Screen: 步骤 5 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the screws found on the four corners of the back of the device.
    • The device pictured is extremely damaged. A normal device should not appear as bent and broken.
    • The screws are very small and may require some patience to get a proper grip.
  6. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 6 中的图像 1,3 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 6 中的图像 2,3 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 6 中的图像 3,3
    • Using the metal spudger, pry the plastic casing around the device.
  7. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 7 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 7 中的图像 2,2
    • Using the metal spudger, gently pull out the motherboard from the plastic casing.
  8. Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 8 中的图像 1,3 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 8 中的图像 2,3 Verizon Jetpack 4G LTE Mobile Hotspot Screen Replacement: 步骤 8 中的图像 3,3
    • Rotate the motherboard so that the screen is facing you.
    • Gently pull up the orange tape to remove the screen.
结论
3等其他人完成本指南。
Analisa Caso
于10/08/18注册
232 声望
创作了2篇指南
团队
Marist, Team S1-G3, Chaterdon Fall 2018 Marist, Team S1-G3, Chaterdon Fall 2018 的会员
MARS-CHATERDON-F18S1G3
3 名成员
创作了8篇指南
5条评论
I would like to know where I can buy the screen from.
Kamil - 回复
Question: I have a cracked screen on my 8800L. I also have a 7730L. Can I put the screen from my 7730L in my 8800L? Will it fit?
masa - 回复
Too bad this guide did not do what most folks are looking for, replacing the screen glass. Where to buy replacement glass and actual screen would be great!
luffman - 回复
for parts and tools scan to the bottom click ifixit, stores, then country or pro wholesale. then it will give you the option tools or parts from there you should be able to find what you desire. clicking the link will take you to another page. Good
Charlie Chick - 回复
These steps do not help find a replacement screen.
Wehilani -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 33
总计 5,223
