跳转到主内容
Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement
你所需要的
  1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Battery: 步骤 1 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Battery: 步骤 1 中的图像 2,2
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 2 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 2 中的图像 2,2
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 3 中的图像 1,1
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
  4. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, SIM Card: 步骤 4 中的图像 1,1
    • Now that the battery is out, the SIM Card should be visible. Simply grasp it and pull it out of the device.
    • The device in picture no longer has a SIM card but a normal device will likely have a SIM card once opened.
  5. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Screen: 步骤 5 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Screen: 步骤 5 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the screws found on the four corners of the back of the device.
    • The device pictured is extremely damaged. A normal device should not appear as bent and broken.
    • The screws are very small and may require some patience to get a proper grip.
  6. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 6 中的图像 1,3 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 6 中的图像 2,3 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 6 中的图像 3,3
    • Using the metal spudger, pry the plastic casing around the device.
  7. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 7 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 7 中的图像 2,2
    • Using the metal spudger, gently pull out the motherboard from the plastic casing.
  8. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 8 中的图像 1,3 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 8 中的图像 2,3 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: 步骤 8 中的图像 3,3
    • Rotate the motherboard so that the screen is facing you.
    • Gently pull up the orange tape to remove the screen.
  9. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Buttons: 步骤 9 中的图像 1,3 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Buttons: 步骤 9 中的图像 2,3 Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Buttons: 步骤 9 中的图像 3,3
    • Now that the motherboard is out, the buttons should come easily out of what's left of the device. If they do not fall out once the motherboard is out, simply poke the buttons from the front and they should separate from the device.
结论
另外一个人完成了本指南。
Madison Asaro
于10/08/18注册
243 声望
创作了2篇指南
团队
Marist, Team S1-G3, Chaterdon Fall 2018 Marist, Team S1-G3, Chaterdon Fall 2018 的会员
MARS-CHATERDON-F18S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 858
