跳转到主内容
Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement
你所需要的
  1. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: 步骤 1 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 步骤 2 中的图像 1,2 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 步骤 2 中的图像 2,2
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 步骤 3 中的图像 1,1
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
结论
Analisa Caso
于10/08/18注册
232 声望
创作了2篇指南
团队
Marist, Team S1-G3, Chaterdon Fall 2018 Marist, Team S1-G3, Chaterdon Fall 2018 的会员
MARS-CHATERDON-F18S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 4,758
