跳转到主内容
Verizon Ellipsis 8 Speaker Replacement
你所需要的
  1. Verizon Ellipsis 8 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Speaker Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Speaker Replacement: 步骤 3 中的图像 1,1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Speaker Replacement: 步骤 4 中的图像 1,1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Verizon Ellipsis 8 Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Verizon Ellipsis 8 Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
    • Remove the speaker from the device.
结论
另外一个人完成了本指南。
Sreedhar Kesari
于11/11/19注册
190 声望
创作了2篇指南
团队
IUPUI, Team S2-G2, Stella Fall 2019 IUPUI, Team S2-G2, Stella Fall 2019 的会员
IUPUI-STELLA-F19S2G2
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 235
