跳转到主内容
Verizon Ellipsis 8 Screen Replacement
你所需要的
  1. Verizon Ellipsis 8 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Screen Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Screen Replacement: 步骤 3 中的图像 1,1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Screen Replacement: 步骤 4 中的图像 1,1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Screen Replacement, Speaker: 步骤 5 中的图像 1,3 Verizon Ellipsis 8 Screen Replacement, Speaker: 步骤 5 中的图像 2,3 Verizon Ellipsis 8 Screen Replacement, Speaker: 步骤 5 中的图像 3,3
    • Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
    • Remove the speaker from the device.
  6. Verizon Ellipsis 8 Screen Replacement, Screen: 步骤 6 中的图像 1,1
    • Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
结论
另外一个人完成了本指南。
Sreedhar Kesari
于11/11/19注册
190 声望
创作了2篇指南
团队
IUPUI, Team S2-G2, Stella Fall 2019 IUPUI, Team S2-G2, Stella Fall 2019 的会员
IUPUI-STELLA-F19S2G2
4 名成员
创作了2篇指南
1指南评论
This guide is incomplete, with several steps and details omitted.
As it is now, this guide is inadequate for anyone who has never done anything like this before. Yet it's also almost completely unnecessary for anyone with a little experience doing similar repairs.
So, it's of almost no use to anyone!
ajfranzman - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 1,224
