跳转到主内容
Verizon Ellipsis 8 Antenna Replacement
你所需要的
  1. Verizon Ellipsis 8 Antenna Replacement, Battery: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Antenna Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Antenna Replacement: 步骤 3 中的图像 1,1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Antenna Replacement: 步骤 4 中的图像 1,1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Antenna Replacement, Antenna: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, lift the motherboard along the top right edge of the device.
  6. Verizon Ellipsis 8 Antenna Replacement: 步骤 6 中的图像 1,3 Verizon Ellipsis 8 Antenna Replacement: 步骤 6 中的图像 2,3 Verizon Ellipsis 8 Antenna Replacement: 步骤 6 中的图像 3,3
    • Once you have access to the antenna, remove it and replace it.
结论
Jack
于02/06/19注册
610 声望
创作了3篇指南
团队
UC Davis, Team S18-G6, Lore Winter 2019 UC Davis, Team S18-G6, Lore Winter 2019 的会员
UCD-LORE-W19S18G6
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 363
