跳转到主内容
Verizon Ellipsis 8 Button Replacement
你所需要的
  1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: 步骤 1 中的图像 1,1
    • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
  2. Verizon Ellipsis 8  Button Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
  3. Verizon Ellipsis 8  Button Replacement: 步骤 3 中的图像 1,1
    • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
结论
Jack
于02/06/19注册
610 声望
创作了3篇指南
团队
UC Davis, Team S18-G6, Lore Winter 2019 UC Davis, Team S18-G6, Lore Winter 2019 的会员
UCD-LORE-W19S18G6
3 名成员
创作了3篇指南
1指南评论
where can i purchase replacement buttons for this device? anyone know? Thanks!!!
Broadcast Depth - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 596
