跳转到主内容
Verizon Ellipsis 7 Rear Facing Camera Replacement
你所需要的
  1. Verizon Ellipsis 7 Rear Facing Camera Replacement, Charging Port: 步骤 1 中的图像 1,3 Verizon Ellipsis 7 Rear Facing Camera Replacement, Charging Port: 步骤 1 中的图像 2,3 Verizon Ellipsis 7 Rear Facing Camera Replacement, Charging Port: 步骤 1 中的图像 3,3
    • Hold down the power button until the screen goes black to turn off the device.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and pull it out after hearing a click.
  2. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 3 中的图像 1,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 3 中的图像 2,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the charging (micro-USB) port.
    • Unscrew the indicated screws using the Phillips #00 screwdriver.
    • The screws shown in the picture are the more common 4.76 mm.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
  4. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the charging port board from the phone using tweezers.
    • Place the replacement charging port into the phone.
    • Be cautious when replacing the ribbon cable onto the new charging port board.
  5. Verizon Ellipsis 7 Rear Facing Camera Replacement, Speaker: 步骤 5 中的图像 1,2 Verizon Ellipsis 7 Rear Facing Camera Replacement, Speaker: 步骤 5 中的图像 2,2
    • Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
  6. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 6 中的图像 1,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 6 中的图像 2,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers carefully lift the connector up to disconnect it from the motherboard.
    • Using tweezers carefully pull the speakers up and out of device.
  7. Verizon Ellipsis 7 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to carefully disconnect the power cable bundle from the motherboard.
  8. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 8 中的图像 1,2 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the 10 screws from the motherboard.
    • The screws shown in the first picture are the more common 4.76 mm.
    • The screw shown in the second picture is shorter, 3.175 mm, than the rest of the screws
  9. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 9 中的图像 1,2 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Remove the 5 antenna cable connectors from the motherboard using a spudger.
  10. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 10 中的图像 1,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 10 中的图像 2,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 10 中的图像 3,3
    • Disconnect the two ZIF connectors that are connected to the motherboard with a spudger. Lift up the metal part of the connector and then pull the connector off of its port
    • Once disconnected pull away from its connector carefully with tweezers.
    • Once the connectors have been disconnected you can gently lift up on the motherboard to remove it from the device.
  11. Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 11 中的图像 1,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 11 中的图像 2,3 Verizon Ellipsis 7 Rear Facing Camera Replacement: 步骤 11 中的图像 3,3
    • Remove the motherboard from the tablet.
    • Use the spudger to disconnect the press lift connector.
    • Carefully flip the motherboard over. Disconnect the camera at the top of the board using tweezers.
结论
另外一个人完成了本指南。
Charles Gorbett
于10/10/16注册
242 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 379
