跳转到主内容
Verizon Ellipsis 7 Battery Replacement
你所需要的
  1. Verizon Ellipsis 7 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Verizon Ellipsis 7 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Verizon Ellipsis 7 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Power down device by holding down the power button until the screen goes black.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and then pull out after hearing a click.
  2. Verizon Ellipsis 7 Battery Replacement: 步骤 2 中的图像 1,2 Verizon Ellipsis 7 Battery Replacement: 步骤 2 中的图像 2,2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pull the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Battery Replacement: 步骤 3 中的图像 1,3 Verizon Ellipsis 7 Battery Replacement: 步骤 3 中的图像 2,3 Verizon Ellipsis 7 Battery Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
结论
11等其他人完成本指南。
Scott Mangin
于01/24/17注册
609 声望
创作了2篇指南
团队
Cal Poly, Team 13-5, Banghart Winter 2017 Cal Poly, Team 13-5, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G5
4 名成员
创作了4篇指南
8条评论
so much for the charging port. You didn’t mention the battery. ?
good1946scout - 回复
Well….ok…..but were we here for removing the charging port? Ha ha….I think not. So how about we lift out the battery and unplug it instead. Takes a bit of effort , it seems. That sucker is stuck down pretty good with some really good double sided tape. Lift carefully. I pried it up with the same plastic case tool I used to remove the back cover. The same tool also helped me remove the battery plug.
David Shaw - 回复
First time on Ifixit and they leave me two steps from the goal; not much of a confidence-builder for this site!
Groove - 回复
WTH? Replacing the battery?
kaycha12 - 回复
Look at the stats..
Why suddenly are so many units failing at or about the same time? I'm not a conspirist but,
Don't you think it's a strange coincidence?
Kermit Allison - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 67
总计 29,492
