简介
In this guide, you will learn how to remove and install the volume wheel of your alarm clock. The process consists of removing the front screen, followed by taking the hardware out of the housing and detaching the power cord. The following step consists of removing the top plastic from the motherboard, being sure to not fully remove the two.
配件
无需配件。
  1. Locate and unscrew the single 2mm Phillips screw from the clock.
    • Locate and unscrew the single 2mm Phillips screw from the clock.
  2. Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock. Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock.
    • Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock.
  3. Get a good grip on the hardware within the shell and pull it all out. Get a good grip on the hardware within the shell and pull it all out.
    • Get a good grip on the hardware within the shell and pull it all out.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
    • With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
  6. Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
    • Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
  7. Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing. Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
    • Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
  8. Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together. Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard. Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
    • Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together.
    • Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard.
    • Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
  9. Gently, pull the tuner wheel up and away from the motherboard. Gently, pull the tuner wheel up and away from the motherboard. Gently, pull the tuner wheel up and away from the motherboard.
    • Gently, pull the tuner wheel up and away from the motherboard.
  10. Gently, pull the volume wheel up and away from the motherboard.
    • Gently, pull the volume wheel up and away from the motherboard.
结论
Robert Myers
于2013年01月11日注册
54 信誉积分
创作了5篇指南
团队
Cal Poly, Team 5-15, Forte Winter 2013 Cal Poly, Team 5-15, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G15
5 名成员
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 197
