简介
In this guide, you will learn how to remove and install the speaker of your alarm clock. The process consists of removing the front screen, followed by taking the hardware out of the housing and detaching the power cord. The next step consists of removing the top plastic from the motherboard, being sure to not fully remove the two. You would then take the speaker in the plastic frame and gently pop it out of its housing.
配件
无需配件。
Locate and unscrew the single 2mm Phillips screw from the clock.
  • Locate and unscrew the single 2mm Phillips screw from the clock.
添加评论
Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock. Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock.
  • Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock.
添加评论
Get a good grip on the hardware within the shell and pull it all out. Get a good grip on the hardware within the shell and pull it all out.
  • Get a good grip on the hardware within the shell and pull it all out.
添加评论
With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
  • With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
添加评论
Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
  • Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
添加评论
Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing. Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
  • Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
添加评论
Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together. Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard. Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
  • Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together.
  • Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard.
  • Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
添加评论
Gently, pull the tuner wheel up and away from the motherboard. Gently, pull the tuner wheel up and away from the motherboard. Gently, pull the tuner wheel up and away from the motherboard.
  • Gently, pull the tuner wheel up and away from the motherboard.
添加评论
Flip over the motherboard and grab hold of the plastic frame. With a small amount of force, push on the plastic clips, away from you, to eject the speaker from its plastic housing. With a small amount of force, push on the plastic clips, away from you, to eject the speaker from its plastic housing.
  • Flip over the motherboard and grab hold of the plastic frame.
  • With a small amount of force, push on the plastic clips, away from you, to eject the speaker from its plastic housing.
添加评论
结论
Robert Myers
于2013年01月11日注册
54 信誉积分
创作了5篇指南
团队
Cal Poly, Team 5-15, Forte Winter 2013 Cal Poly, Team 5-15, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G15
5 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 215
