跳转到主内容
Venturer CR20 Power Cord Replacement
你所需要的
  1. Venturer CR20 Power Cord Replacement, Front Screen: 步骤 1 中的图像 1,1
    • On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
  2. Venturer CR20 Power Cord Replacement: 步骤 2 中的图像 1,2 Venturer CR20 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Using a moderate amount of force, position the screwdriver in the crack between the front screen and the main body of the clock (as shown) and push the screen away from the main body of the clock.
  3. Venturer CR20 Power Cord Replacement, Power Cord: 步骤 3 中的图像 1,2 Venturer CR20 Power Cord Replacement, Power Cord: 步骤 3 中的图像 2,2
    • Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
  4. Venturer CR20 Power Cord Replacement: 步骤 4 中的图像 1,3 Venturer CR20 Power Cord Replacement: 步骤 4 中的图像 2,3 Venturer CR20 Power Cord Replacement: 步骤 4 中的图像 3,3
    • Using your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
结论
另外一个人完成了本指南。
Robert Myers
于01/11/13注册
54 声望
创作了5篇指南
团队
Cal Poly, Team 5-15, Forte Winter 2013 Cal Poly, Team 5-15, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G15
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 380
