跳转到主内容
Vent/Bleed Coolant System on BMW E60/E90
视频概述
    • Insert key in the dash or steering column.
    • With foot OFF the brake (don't want to start the car), push the start button (headlamps and interior systems come on).
    • Turn both temp dials as high as they will go and put the fan on the lowest setting.
    • Push the accelerator pedal in for ten seconds then let go - you will hear the water pump cycle on.
    • Set a timer for 12-15 minutes. In this time period, you will hear the water pump cycle on and off and coolant gurgling at the reservoir.
    • After 12-15 minutes turn the car off, remove the reservoir cap and check the fluid - it should be slightly below where you started.
    • Start your car. Watch your temperature. If the car will run without overheating you're done. If you will notice that the temperature is rising repeat these steps.
结论
另外一个人完成了本指南。
lifeoftech
于11/04/09注册
187 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 118
过去 30 天: 474
总计 26,754
