跳转到主内容
Vent Panel Disassembly
你所需要的
  1. Vent Panel Disassembly, Remove Service Panel Screws: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
  2. Vent Panel Disassembly, Dislodge Service Panel: 步骤 2 中的图像 1,3 Vent Panel Disassembly, Dislodge Service Panel: 步骤 2 中的图像 2,3 Vent Panel Disassembly, Dislodge Service Panel: 步骤 2 中的图像 3,3
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
  3. Vent Panel Disassembly, Remove screw covers: 步骤 3 中的图像 1,1
    • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
  4. Vent Panel Disassembly, Unfasten vent panel: 步骤 4 中的图像 1,2 Vent Panel Disassembly, Unfasten vent panel: 步骤 4 中的图像 2,2
    • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
    • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
  5. Vent Panel Disassembly, Remove vent panel: 步骤 5 中的图像 1,2 Vent Panel Disassembly, Remove vent panel: 步骤 5 中的图像 2,2
    • Remove the vent panel by lifting directly up to dislodge it from the brace.
结论
iodyne
于01/01/22注册
432 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 198
