跳转到主内容
Velocity NoteMagix M10 A82 Keyboard Replacement
你所需要的
  1. Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Keyboard Replacement: 步骤 2 中的图像 1,2 Velocity NoteMagix M10 A82 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  4. Velocity NoteMagix M10 A82 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  5. Velocity NoteMagix M10 A82 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
结论
Sam Middleton
于10/01/13注册
401 声望
创作了4篇指南
团队
Cal Poly, Team 14-9, Forte Fall 2013 Cal Poly, Team 14-9, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G9
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 636
