跳转到主内容
Velocity NoteMagix M10 A82 Hard Drive Replacement
你所需要的
  1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Hard Drive Replacement: 步骤 2 中的图像 1,2 Velocity NoteMagix M10 A82 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
  4. Velocity NoteMagix M10 A82 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift the HDD plate off of the back to reveal the hard drive.
  5. Velocity NoteMagix M10 A82 Hard Drive Replacement: 步骤 5 中的图像 1,2 Velocity NoteMagix M10 A82 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Use the spudger to push the area above the connector on the hard drive to the right.
    • Lift the hard drive gently from the computer with the spudger.
结论
Sam Middleton
于10/01/13注册
401 声望
创作了4篇指南
团队
Cal Poly, Team 14-9, Forte Fall 2013 Cal Poly, Team 14-9, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G9
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 297
