跳转到主内容
Velocity Micro Cruz T301 Motherboard Replacement
你所需要的
  1. Velocity Micro Cruz T301 Motherboard  Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Insert a small opening tool between the rear panel and the tablet.
  3. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 3 中的图像 1,1
    • The large opening tool is not needed any more.
  4. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 4 中的图像 1,2 Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 4 中的图像 2,2
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 5 中的图像 1,1
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 6 中的图像 1,1
    • Using a plastic Spudger remove the battery connector.
  7. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 7 中的图像 1,1
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  8. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 8 中的图像 1,1
    • Place a metal Spudger between the tablet and the back cover.
  9. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 9 中的图像 1,1
    • Move the spudger around the tablet to release the clips attached to the tablet.
  10. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 10 中的图像 1,1
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  11. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 11 中的图像 1,1
    • This guide shows the use of incorrect tools. Always use ESD safe tools when dealing with delicate internal components.
    • Use a nylon spudger to remove the top plug connector from the motherboard.
  12. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 12 中的图像 1,2 Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 12 中的图像 2,2
    • Use a metal spudger to remove both screen cable connectors
  13. Velocity Micro Cruz T301 Motherboard  Replacement: 步骤 13 中的图像 1,1
    • use openning tools to remove the motherboard.
结论
Ahmed
于10/05/16注册
227 声望
撰写一个指南
团队
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 171
