跳转到主内容
Velocity Micro Cruz T301 Battery Replacement
你所需要的
  1. Velocity Micro Cruz T301 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert the plastic iFixit opening tool into the SD port. Orient the iFixit opening tool so that the edge faces the rear panel.
  2. Velocity Micro Cruz T301 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the iFixit opening tools to pry open a gap between the tablet and rear panel.
  3. Velocity Micro Cruz T301 Battery Replacement: 步骤 3 中的图像 1,2 Velocity Micro Cruz T301 Battery Replacement: 步骤 3 中的图像 2,2
    • Move the small tool opener around the rear panel to free the 12 clips.
  4. Velocity Micro Cruz T301 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the four screws in the metal battery housing using the Phillips #0 screwdriver.
  5. Velocity Micro Cruz T301 Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery using the spudger.
  6. Velocity Micro Cruz T301 Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of its place with a nylon spudger.
    • This photo shows the use of an incorrect tool. Always use an ESD safe tool, like the nylon spudger, when dealing with delicate components.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 531
