跳转到主内容
Velocity Micro Cruz Battery Replacement
你所需要的
  1. Velocity Micro Cruz Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert a plastic opening device into the small crack separating the screen and the back of the device.
    • After the back of the device is separated, remove the back and you can now access the battery.
    • When prying the back of the device off, be careful as this could cause small damages or cracks to the screen.
  2. Velocity Micro Cruz Battery Replacement: 步骤 2 中的图像 1,1
    • The battery is connected to the motherboard where the picture indicates.
    • To remove the battery, you must first detach the battery wire connecting it from the motherboard. To do this, simply gently, but firmly, pull it out of the motherboard connector.
  3. Velocity Micro Cruz Battery Replacement: 步骤 3 中的图像 1,1
    • Simply pry the battery out of the device at this point. The battery may be held in place by adhesive glue and require a nylon spudger or plastic opening tool to help pry it out.
    • Place your new battery in place of the old one. Connect the new battery's wire to the motherboard and you are finished.
结论
另外一个人完成了本指南。
Hunter Ralston
于10/10/16注册
122 声望
撰写一个指南
团队
Texas Tech, Team 12-4, Bennett Fall 2016 Texas Tech, Team 12-4, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G4
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 1,046
