跳转到主内容
Varmilo MA87M Love Birds Switch Replacement
你所需要的
  1. Varmilo MA87M Love Birds Switch Replacement, Switch: 步骤 1 中的图像 1,3 Varmilo MA87M Love Birds Switch Replacement, Switch: 步骤 1 中的图像 2,3 Varmilo MA87M Love Birds Switch Replacement, Switch: 步骤 1 中的图像 3,3
    • Take the key removal tool and push down on the key until the tool clicks into place.
    • Pull up with the tool to remove the keycaps.
    • When the keycaps are removed they can be cleaned at this time.
    • Make sure the keyboard is disconnected from the computer or the computer is turned off during this process.
  2. Varmilo MA87M Love Birds Switch Replacement: 步骤 2 中的图像 1,2 Varmilo MA87M Love Birds Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the switches from the keyboard by aligning the keyboard remover along the groves at the bottom of the switch.
    • Use caution; if you damage a switch, you will need to replace it.
  3. Varmilo MA87M Love Birds Switch Replacement: 步骤 3 中的图像 1,1
    • Insert the new switch into the empty slot where the old switch was and push down on the new switch.
  4. Varmilo MA87M Love Birds Switch Replacement: 步骤 4 中的图像 1,2 Varmilo MA87M Love Birds Switch Replacement: 步骤 4 中的图像 2,2
    • When the new switch is inserted, the keycap can be slotted on and pushed easily back into place.
结论
团队
Team Jansport Team Jansport 的会员
Community
1 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 46
总计 501
