跳转到主内容
VanMoof No 3 Light Battery Replacement
你所需要的
  1. VanMoof No 3 Light Battery Replacement, Battery: 步骤 1 中的图像 1,3 VanMoof No 3 Light Battery Replacement, Battery: 步骤 1 中的图像 2,3 VanMoof No 3 Light Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: 步骤 2 中的图像 1,1
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: 步骤 3 中的图像 1,2 VanMoof No 3 Light Battery Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: 步骤 4 中的图像 1,2 VanMoof No 3 Light Battery Replacement, Unsolder the battery: 步骤 4 中的图像 2,2
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: 步骤 5 中的图像 1,3 VanMoof No 3 Light Battery Replacement, Solder the new battery: 步骤 5 中的图像 2,3 VanMoof No 3 Light Battery Replacement, Solder the new battery: 步骤 5 中的图像 3,3
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: 步骤 6 中的图像 1,1
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: 步骤 7 中的图像 1,3 VanMoof No 3 Light Battery Replacement, Reassemble: 步骤 7 中的图像 2,3 VanMoof No 3 Light Battery Replacement, Reassemble: 步骤 7 中的图像 3,3
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: 步骤 8 中的图像 1,2 VanMoof No 3 Light Battery Replacement, Reassemble 2: 步骤 8 中的图像 2,2
    • Test the light turns on
    • Screw the back plate to the lense.
结论
3等其他人完成本指南。
Martin Hampton
于02/13/16注册
1,308 声望
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 34
过去 30 天: 153
总计 7,802
