跳转到主内容
加入维修社区 - 创建账户
Vanmoof No 3 Replacement Mudguards
  1. Vanmoof No 3  Replacement Mudguards, Get the Mudguards: 步骤 1 中的图像 1,1
    • Make sure you get 2 mudguards, one set of stays that are straight for the rear, and a second that have a bend. Also make sure you have the two rear connection pieces.
  2. Vanmoof No 3  Replacement Mudguards, The problem: 步骤 2 中的图像 1,1
    • You need to cut both sides of the mudguard so it can fit between the chain stays, and drill a new hole to attach to the bottom of the frame.
  3. Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: 步骤 3 中的图像 1,3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: 步骤 3 中的图像 2,3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: 步骤 3 中的图像 3,3
    • The rear mudguard will need to be cut at the front.
    • First cut at parallel to the bottom about 16mm long
    • Second cut is 7mm in from the rounded edge
  4. Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: 步骤 4 中的图像 1,3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: 步骤 4 中的图像 2,3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: 步骤 4 中的图像 3,3
    • Bend the edges over so you make a rounded lip
  5. Vanmoof No 3  Replacement Mudguards, Drill the new hole: 步骤 5 中的图像 1,1
    • Drill the frame attachment hole
    • Bolt to the frame
结论
Martin Hampton
于02/13/16注册
1,350 声望
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 9
总计 1,136
