跳转到主内容
Vacuum Cleaner Brush Roll Replacement
你所需要的
  1. Vacuum Cleaner Brush Roll Replacement, Brush Roll: 步骤 1 中的图像 1,1
    • Be sure to unplug the device from the wall outlet before disassembling.
    • Remove the bottom head of the vacuum cleaner by pressing the push button.
  2. Vacuum Cleaner Brush Roll Replacement: 步骤 2 中的图像 1,2 Vacuum Cleaner Brush Roll Replacement: 步骤 2 中的图像 2,2
    • Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
  3. Vacuum Cleaner Brush Roll Replacement: 步骤 3 中的图像 1,1
    • Separate the top portion of the head from the bottom.
    • Make sure not to pull off or damage the connected wires.
  4. Vacuum Cleaner Brush Roll Replacement: 步骤 4 中的图像 1,1
    • Slip off the belt.
  5. Vacuum Cleaner Brush Roll Replacement: 步骤 5 中的图像 1,2 Vacuum Cleaner Brush Roll Replacement: 步骤 5 中的图像 2,2
    • Pull the brush roll from its slots.
  6. Vacuum Cleaner Brush Roll Replacement: 步骤 6 中的图像 1,2 Vacuum Cleaner Brush Roll Replacement: 步骤 6 中的图像 2,2
    • Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
  7. Vacuum Cleaner Brush Roll Replacement: 步骤 7 中的图像 1,1
    • Return the clean brush roll and re-situate the belt to secure it in place.
结论
To reassemble your device, follow the disassembly instructions in reverse order.
Kaitlyn Sheets
于01/19/16注册
117 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 58
总计 2,598
