简介
If the brush roll on your Bissell Vacuum 2610E is worn out and isn't cleaning as well as it used to, it might be time to replace the brush. This quick guide will show how you how to replace the brush roll with nothing more than a Phillips #0 screwdriver and about 20 minutes of your time.
你所需要的
Lay the vacuum flat on the ground, then use a sturdy object to prop up the bottom.
即将完成!
结论
另外一个人完成了本指南。
