跳转到主内容
VTech Write and Learn Creative Center Magnetic Screen Replacement
你所需要的
  1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 步骤 1 中的图像 1,3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 步骤 1 中的图像 2,3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: 步骤 2 中的图像 1,1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
  3. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 步骤 3 中的图像 1,2 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 步骤 3 中的图像 2,2
    • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
  4. VTech Write and Learn Creative Center Magnetic Screen Replacement: 步骤 4 中的图像 1,1
    • Gently push the edges of the screen to remove it from the front case.
结论
团队
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G2
3 名成员
创作了12篇指南
2指南评论
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - 回复
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 1,613
